Please help: Oxygen sensor location?
Old Aug 22, 2005 | 08:01 PM
darrman's Avatar
darrman
Hi everybody, I have a '91 Explorer Sport, and I am getting ready to change the HO2s's and according to the repair manual, I have two sensors, one on the left exhaust manifold, and one in the Y-pipe. Now I have already found the one in the pipe, but I have searched every inch of both manifolds and have found nothing. Mine is a August of '90 build, and I have found a few parts were changed or moved around from the later '91 builds, could this be another?
I would appreaciate any help, its driving me nuts!
Old Aug 22, 2005 | 09:57 PM
mrshorty's Avatar
mrshorty
sonme DIY manuals are too generic for such information. '91, '92, and some '93 Explorers only had one O2 sensor (the one in the Y pipe that you've found). I recommend that you stop looking for the non-existent 2nd O2 sensor.
Old Aug 23, 2005 | 06:20 AM
don96exp's Avatar
don96exp
I believe multiple O2 sensors were introduced starting with the 1996 models which had the OBDII system. Prior to that only one sensor. If your manual covers multiple years of Explorers that could the reason for the confusion.
Old Aug 23, 2005 | 07:02 AM
darrman's Avatar
darrman
Thanks, that helps alot! The manual I have claims that 91-95 used two sensors, and then 96 and up used four. I am going to go ahead and repleace the one in the pipe today! Thanks again!
Old Aug 23, 2005 | 10:56 AM
mrshorty's Avatar
mrshorty
Actually, some '93 and all '94 and '95 Explorers had 2 O2 sensors, so multiple O2 sensors are possible in EEc-IV/OBD-1 vehicles. You just have to know which ones.
Old Aug 23, 2005 | 04:40 PM
Jharger's Avatar
Jharger
My 93 has 2 sensors but it is also a CA car with sequential fuel injection and CA emmissions, EEC-IV, OBD1.
Old Aug 23, 2005 | 06:53 PM
don96exp's Avatar
don96exp
I stand corrected, that's good to know. Sounds like ford had a few different systems on the pre '96 models
