Gas tank venting
Old Aug 22, 2005 | 06:33 PM
noyozoid's Avatar
noyozoid
Gas tank venting
I Have a 1998 Windstar. When I take the gas cap of a hissing sound occurs, therefore I know that Iu have a venting problem, but what. The code reader gives me code 1450 " Unable to bleed up fuel tank vacuum". Where should I start to find the problem.
Old Aug 23, 2005 | 04:33 AM
Dannym's Avatar
Dannym
I would think replacing the gas cap would do it.
Old Aug 23, 2005 | 07:46 AM
Ian F's Avatar
Ian F
Might also be a clog in the EVAP system, which vents tank gases into the intake manifold. But as I think about it, the gas cap is probably your culprit....
Old Aug 23, 2005 | 08:53 AM
noyozoid's Avatar
noyozoid
Thanks guys I will try the gas cap for starters. If it doesn't do the trick I will be asking for more help.
