More CEL problems
Old Aug 22, 2005 | 06:08 PM
1970Custom's Avatar
1970Custom
Question More CEL problems
I've been on the hunt for the CEL culpret in my '93 F-150. So far I've replaced the EGR valve, FPR, Complete tune up, timing, and others I'm forgetting.
SO, I pulled the codes today and it said the power steering pressure switch was open, could this cause a poor performing truck i.e stalling, fuel clouds out the pipes & a rough idle?
I'm going to replace the O2 censor tonight and see if that won't help.
And to think, this all started with the talk of selling the truck....
=Eric
Old Aug 22, 2005 | 08:39 PM
924x2150's Avatar
924x2150
Double-check the dynamic test, that is the key-on/engine running procedure. you may need to turn the steering wheel back and forth to test that switch.
I believe there are three inputs required from the driver during KOER test:
tap the brake, spin the wheel, and goose the throttle. These are to be done after the computer prompts the driver.
Did you have stored, "continuous codes" and what where they?
PS. that power steering code may have happened because of an improper procedure, but it can be erased by removing the STI test jumper during the continuous codes tests, stopping mid test resets stored codes to zero. Retry the dynamic test and I bet that code doesn't return.
Old Aug 23, 2005 | 08:58 PM
1970Custom's Avatar
1970Custom
The O2 censor kinda fixed the problem, but it still has a rough idle.
I read a thread a couple days ago about cleaning the throttle body and parts corrisponding items, what am I looking for??
=Eric
Old Aug 23, 2005 | 09:13 PM
Popa Tim's Avatar
Popa Tim
Try cleaning the TB and IAC. A search will give you more info than you need.
Let us know if it fixed your problem.
Popa Tm
Old Aug 30, 2005 | 05:45 PM
1970Custom's Avatar
1970Custom
It was the O2 sensor, put the new one in and noticed immidiotly that there was a difference.
Took it about two days of rough idle and my the third the truck was back to normal. Ironically what made a major difference, maybe just ironic, but I went plunging through a huge puddle, and it got better I'm guessing it was the WOT that helpped clean things out.
=Eric
