98 Explorer A/C question
Old Aug 22, 2005 | 01:49 PM
oskie's Avatar
oskie
My accumulator has a leak and I am going to replace it. The book says add oil to the accumulator (whatever was in the old one, plus two ozs.???) If my accumulator was leaking, how do I know the correct amount?
Old Aug 23, 2005 | 09:34 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Put 3-4 oz in it, you'll be ok. It's not an exact science. The engineers would want you to remove all components, drain them all, and add like 4 oz to condenser, 2 oz to evaporator, 4 oz to compressor, etc, etc.. but we all know that's just not practical.
You might want to replace your oriface tube while you've got the accumulator off as well... it's less than ten bucks, and probably clogged full of junk.
Good luck
Old Aug 24, 2005 | 01:43 PM
oskie's Avatar
oskie
Thanks for the response. Another question it says to put oil in throught the "shrader valve" where on the accumulator is the shrader valve?
Old Aug 28, 2005 | 11:09 PM
MazdaRangerGuy
It's where you would put in the freon... disregard that unless you've already installed the part. Just pour it into the opening in the tube just before intallation.
Old Aug 29, 2005 | 07:38 AM
oskie's Avatar
oskie
simple enough, thank you
