The parking brake on my 99 F250SD is stuck ON. The hande cable is still good, moving the arm as far as it chould - but the brake won't release (the long cable under the truck is still attached and taught)... any ideas?
Under the dash appears to be working fine - I pull the lever, the cable moves, which moves the arm as far as it can go (it moves all the way to the stop) - except nothing releases. I use the parking brake all the time - the truck has only sat for around a week (and it hasn't been raining). If I pull the lever and then try to help the brake come back up - it won't move... I'll WD-40 the cables/etc under the truck. If anyone can think of anything else I'd really appreciate it - having it towed from where it is will NOT be fun...
