Modular V10 (6.8l)
spark plug torque
Old Aug 20, 2005 | 08:01 PM
jwc9's Avatar
jwc9
spark plug torque
Ok the search on here is shut down and I need to know what to torque the plugs at? 2000 v-10 thanks
Old Aug 20, 2005 | 08:26 PM
windyhill's Avatar
windyhill
I did 15ft/lbs I think that was pritty close.
Old Aug 21, 2005 | 06:22 AM
jwc9's Avatar
jwc9
Thanks windyhill
Old Aug 21, 2005 | 09:47 AM
jwc9's Avatar
jwc9
Ok I just got done changing plugs. It took about 2 hours. #5 was by far the hardest to do. I torqueed them at 160 inch pounds. Used antiseize also. None really looked worse than others as far as rust on the threads.With 64000 miles I did it because I wanted to make sure they were put in properly.
Old Aug 22, 2005 | 09:10 AM
Big Orn's Avatar
Big Orn
That's good - the max is 14 ft/lb or 168 in/lb.
That's what is called responsible maintenance...
Did you happen to inspect the boots while you were at it?
Old Aug 22, 2005 | 02:50 PM
jwc9's Avatar
jwc9
Yes I did take a look, I noticed no cracking or anything out of the ordinary.The contact inside was not corroded. Was There anything else to look for? Thanks
Old Aug 22, 2005 | 04:10 PM
Big Orn's Avatar
Big Orn
The unseen things are the trickiest...
When I inspect the boots I take some talcum powder and lightly dust them - sort of like Zylgo testing metals...but better. You can rub in the dust and then twist and bend the boots to see if there are any cracks. I have found that the rubber that they make these boots from is about as cheap a rubber as you can find.
On humid, wet, muggy days down here in the "Land-O-The-Lakes" the moisture can get past the seal (if you want to call it that) and get into the plug cavity.
But, boots aren't that expensive and replacing a couple or five won't break me, so if I see just a little failure, I go get new ones.
