bad fuel mileage
Old Aug 19, 2005 | 05:05 PM
smack518's Avatar
smack518
bad fuel mileage
I have a 95 F150, 4.9 5 speed that is getting only 9 to 10 mpg but the truck idles fine and runs well except for a small mid throttle stumble. Had a new exhaust put on from the converter back. My mechanic fixed an intake and exhaust leak and put a new EGR, Egr solenoid, air charge sensor and temp sensor. The sparkplugs were and are still white indicating a lean mixture even after repairs. I ran a can of Seafoam through the EFI and the tank and it helped somewhat but the mileage is still in the toilet. The air charge tube was leaking so he removed it telling me that it would not hurt the performance. Any ideas or suggestions would be helpful.
Old Aug 19, 2005 | 05:26 PM
quicklook2's Avatar
quicklook2
did you put a new oxygen sensor in? plug wires, cap? clean throttle body by taking it off and cleaning it?
Old Aug 19, 2005 | 05:31 PM
smack518's Avatar
smack518
There was no codes so the O2 sensor has not been changed. The Throttle body was removed by the mechanic but not sure if he had cleaned it and a complete tune was don 4 months ago
Old Aug 19, 2005 | 05:36 PM
andym's Avatar
andym
Check the fuel pressure regulator and change the O2 sensor anyway.
Old Aug 19, 2005 | 06:14 PM
924x2150's Avatar
924x2150
Is it a daily driver or is it hauling loads in the back everyday?
My 92 300/E4OD is running the best ever, I can only get 14.000000 MPG's out of her just going back and forth to work.
Is the coolant level stable or do you have to add a quart to the reservoir every week? What color is your exhaust and how does the exhaust smell? How many miles on the engine? Are you a lead foot?
The tube that is missing...is that the smog pump tube running fresh air to the CAT Convertor, or the tube that comes off the exhaust that feeds into the EGR and upper intake?
Also, you may need to learn about the IAC operation, it may be fouled with carbon.
Have you tested the vacuum on that engine lately???? 20 to 22 inches of pull would be very nice.
Old Aug 19, 2005 | 06:20 PM
handyman43358's Avatar
handyman43358
That could be exactly your problem. A faulty O2 sensor will not read right which will let your engine run lean or rich. It assumes everything is fine the way it is when really its not.
Old Aug 19, 2005 | 07:18 PM
smack518's Avatar
smack518
The truck is a daily driver and I don't haul any loads. The engine has 27000 miles on it. I used to average 18 hwy and 15 city. I have driven it very easily not pushing over 2000 rpm and there was no increase in the mileage. The coolant level is fine and there are no leaks. I will check the IAC to see if it is fouled. Can the O2 sensor go bad and not throw a code in the computer.
Old Aug 19, 2005 | 07:51 PM
handyman43358
Yea. Typically thats what will make your computer throw a code. If your truck instantly got that bad of mileage and theres no code, then change the O2 sensor and then a new one could tell you what the problem is. The O2 sensor could think theres a rich mixture (although it could be wrong) and could tell the computer to lean the fuel up a little bit, causing a lean mixture. If I remember right, if an engine runs too lean, the MPG's will go down. Not sure though...
