Shorty header problem
Old Aug 19, 2005 | 04:54 PM
F150'89's Avatar
F150'89
I have a set of Flowtech headers on my '89 F150 and have damaged the collector on the pass side trying to make it seal to the headpipe. The parts store where I got them from will not replace them because they only came with a 90 day warranty, I have sent to e-mails to Flowtech asking if the made a repair kit but have not recived a response from them. Anyone know of a fix for this problem or am I just SOL and should throw them in the trash can.
Old Aug 19, 2005 | 07:41 PM
95 F150's Avatar
95 F150
I guess you could weld the collector to the exhaust pipe and just cut the exhaust pipe and run some type of slip joint with a clamp on it in case you have to remove the header for some reason.
