Zoodad MOD
Old Aug 19, 2005 | 04:09 PM
Firemedic61's Avatar
Firemedic61
Question Zoodad MOD
Has anyone experienced any problems with the "zooman mod"? Problems with rain or snow getting in the air filter or worse? I am going to do the modification to my 6.0 assuming there have not been any problems!
Old Aug 19, 2005 | 06:00 PM
Firemedic61
Sorry, I guess I had the name wrong. It's not the "zooman Mod." It's called the Zoodad Mod. It is basically cutting a hole in front of the intake tube to create a ram air. I have read about some people that have done it and put screen material in front of the hole to keep the bugs out of the filter. My understanding is that it give the motor alot more air even with a stock filter. Has anyone that has done this had any problems?
Old Aug 19, 2005 | 06:36 PM
ryaneverk2's Avatar
ryaneverk2
If you search for Zoodad on here, you'll probably find some info on it. I know there's quite a bit of info over at the diesel stop site. Generally, people notice that they get more, cooler air into the intake, and they also say they get a little increase in the seat-of-the-pants readings. Some put screens over the hole, others don't. That's all I can really say on it... searching here at at TDS will help for sure.
Old Aug 19, 2005 | 06:44 PM
Skipped_link's Avatar
Skipped_link
I've had mine done for over a year now with no problems, I've driven in snow & heavy rain with no bad effects, I can't say there is much performance difference, maybe a little but it's been long enough ago that I don't remember,
Old Aug 19, 2005 | 06:50 PM
satcom40's Avatar
satcom40
I've done it, I have a screen behine the grill to keep bug and rock out of my radirator. I've not had a problem with it.
Old Aug 19, 2005 | 07:04 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Changed the title for you...
And, welcome to FTE.
Check out our Guidelines:
https://www.ford-trucks.com/guidelines.html
And the Read First: notices at the top of each forum, it will help you understand and navigate FTE easier.
See you around...
BigF350
Old Aug 21, 2005 | 01:40 AM
Ford-Red's Avatar
Ford-Red
I recently drilled a 2.5" hole in my 2005 F250 PSD. My stock air filter has its inlet about 2" behind the flat radiator side-support panel (no lower snorkle). I may cut the intake tube shorter later. Seems to be an obvious improvement to open an air passage direct to filter before buying an aftermarket filter with this advantage. Pictures of engine damage by fautly aftermarket air cleaner performance are scary (maintenace of these is apparently critical).
Grill was easily removed with upper bolts and downward push of screwdriver on lower clips. I installed a short deflector in front and towards the side of the new hole to avoid possible direct shot of water through the grill. This measure was based upon responses in this forum.
Truck seemed to perform better (less lag) and pleasing growling sound near the grill. Also, I removed a piece of clear tape over 0.5" hole on top support edge in front of the secondary air line. Not sure of its original purpose for blocking air to this frame channel. I have not seen any comments on this yet.
FYI, so far my biggest fuel milage improvement with basically stock truck has been with synthethic oil use (~2 mpg).
Old Aug 21, 2005 | 06:36 AM
HeavyAssault's Avatar
HeavyAssault
These are pics of my own intake mods. Tools needed: hole saw for your drill and a bandsaw if you got one.
http://webpages.charter.net/fordtruc...s/DSC01859.JPG
http://webpages.charter.net/fordtruc...ddedIntake.jpg
Old Aug 21, 2005 | 06:56 AM
Lnd Svyr's Avatar
Lnd Svyr
Just a question:
If this Zoodad was a good idea, don't you think Ford would have copied and implemented it by now?
Old Aug 21, 2005 | 07:21 AM
HeavyAssault
Well I think lockers are a good idea, they have yet to do that for your truck.
Old Aug 21, 2005 | 07:43 AM
Lnd Svyr's Avatar
Lnd Svyr
You make a good point. (I think I read somewhere hereon that Ford may have one coming out.)
Old Aug 21, 2005 | 10:41 AM
wolffee's Avatar
wolffee
Heavy Assault:
I have dont the same thing as you but without the cutting of the actual filter box i have only drilled the holes.. I have only had it for about 3 weeks now and only had a slight rain. How long have you had yours like this and have you ever checked your filter to see if it was wet after a heavy rain ...Mine is wide open with the holes as in no deflectors or screens whatsoever and i had a buddy give it some gas in park and i put my hand in front and that hole really sucks some air in. im a little worried now about how it might go down the high way in the rain sucking that water in... especailly us guys and gals with the 04 and below as you 05 guys have a little thicker grill blocking it.. Mine is clearly visable from the front of the truck....
thanks
ryan
Old Sep 1, 2005 | 08:21 AM
lwilcox's Avatar
lwilcox
3rd Gear
1st post. Having trouble posting a picture. I have D&D "bullseyes" in my truck. They have a coarse foam that keeps water, bugs, etc out.
Old Sep 1, 2005 | 04:38 PM
BigF350's Avatar
BigF350
FTE Emeritus
lwilcox,
Welcome to FTE.
As for posting pictures, you can create a gallery. Click on User CP in the top right, then edit gallery.
See you around...
BigF350
Old Sep 1, 2005 | 10:37 PM
jackofalltrades's Avatar
jackofalltrades
I did the Zoodad mod just less than a year ago. I've driven in pouring rain and heavy wet snow to light fluffy snow. I have not experienced any issues other than better cool air to my turbo since the mod.
-Steve
