400 flat tops
Old Aug 18, 2005 | 09:28 PM
mattselland's Avatar
mattselland
400 flat tops
I've looked all over jegs and summit and i cant find a set of standard bore flat tops for a 400, i didnt even see a stock piston for a standard bore. Is there anywhwere i can get a good speed pro or kb or other good brand forged flat top piston that will fit right in without bushings or anything to get me to about 9.5 to 1 compression in standard bore?
Old Aug 18, 2005 | 10:03 PM
Grenouille's Avatar
Grenouille
Try http://www.73-79fordtrucks.com/pistons.html
Old Aug 18, 2005 | 10:20 PM
mattselland
Ive looked at that website already and i dont see anything in standard bore, do you think it would be worth it to call and ask
Old Aug 18, 2005 | 10:21 PM
Torque1st's Avatar
Torque1st
Posting Legend
You never use std bore pistons unless you have a virgin block.
Old Aug 19, 2005 | 12:53 AM
TMI's Avatar
TMI
I can get you the Badger flat top pistons in a standard bore if you like. I have 1 set of the Hypereutectic flat top pistons left that are standard bore. These are pistons that have a "Zero" deck height. 3rd option is we have forged pistons coming any day now. They are a zero deck height piston and a flat top. Only down side is they require bushing the rods, and they will start at .020" O/S
The following link shows the forged stroker piston, the ones coming will look identical.
http://www.tmeyerinc.com/400stroker.html
http://www.tmeyerinc.com/cart400pistons.htm
Old Aug 19, 2005 | 02:03 AM
tankglh21's Avatar
tankglh21
hey tim,
if mattsellsand doesnt want that set of pistons you have, i am interested in them.
Old Aug 19, 2005 | 02:05 AM
tankglh21's Avatar
tankglh21
wait i am sorry i didnt read it correctly. i am bored .040 and already have rings, i just need pistons. can you hook me up....sorry for hijacking the thread
Old Aug 19, 2005 | 12:16 PM
mattselland
Hey that sounds like a good deal, the badger flat tops, do these require bushings too? Will the hypereutectic pistons work well in a stock motor? wat kind of compression can i expect with 2v 400 heads? how much will it cost for a set of eight? do you have a set of rings to go with them? thanks for the help.
Old Aug 21, 2005 | 06:55 PM
mattselland
TMI, Do you still have those flat tops for sale?
Just wondering if you forgot
Old Aug 21, 2005 | 11:15 PM
TMI's Avatar
TMI
The Badger and the Hyper pistons do not require bushings at all. The Badgers sit down in the hole about .080" They hypers, have a zero deck height, at least anothe 1/2 point of compression.
Old Aug 21, 2005 | 11:18 PM
mattselland
ok, I like compression, ill get the hyper. i dont have to worry bout valves hitting them or anything right, they just go right in? I also need a set of rings for them, can i order them off your website?
fordjeep
Jun 16, 2009 06:02 PM
foof187
Apr 23, 2005 04:02 AM
supertruck
Alberta Chapter
Apr 7, 2004 12:41 AM
kopfenjager
Feb 19, 2003 11:09 AM
Bill_Beyer
Jun 30, 2002 12:26 AM
