351w starting problem
Old Aug 18, 2005 | 06:10 PM
78 Ranger's Avatar
78 Ranger
my 78 f250 has recently started to start harder. it has a 351w and once it starts it runs perfect-NO power loss,missing or rough idle. it just seems that i have to hold the key longer and longer every time in order for it to start. once it has started and run it will start right back up when it's hot. i was thinking fuel filter because it's been a while so i'll try that first
Old Aug 20, 2005 | 10:09 PM
Franklin2's Avatar
Franklin2
See if pumping the accelerator twice or 3 times before cranking helps or hurts the problem.
Old Aug 21, 2005 | 07:20 PM
78 Ranger's Avatar
78 Ranger
that's what i always did before and worked fun but now i just keep pumping and it will start up eventually
Old Aug 22, 2005 | 09:09 PM
Franklin2's Avatar
Franklin2
You may have a wire off or missing on the starter relay, if it has two small posts on it.
To help the engine start quicker, the factory puts a full 12 volts to the coil + during cranking. After the engine has started, the coil gets it's voltage through a resistor which puts less than 12 volts to the coil.
Put a meter on the coil + and the engine block, and read the voltage during cranking and then after it starts. You should have a fairly high reading during cranking, and then you should have around 9 volts when it's running.
I am assuming you have done a tune up lately and your sparkplugs are in good shape.
Ford Explorer Tremor Review: Best Explorer Ever
Slideshow: a first-drive review of the 2026 Ford Explorer Tremor, off-road and on!
By Michael S. Palmer | 2026-07-07 13:10:58
10 Cheap Ford Trucks & SUVs That are the Most Fun to Drive!
Slideshow: 10 cheap Ford trucks and SUVs that are the most fun to drive.
By Joe Kucinski | 2026-07-07 10:36:13
5 BEST / 5 WORST Selling Ford Models in 2026 (So Far!)
Slideshow: 5 best and 5 worst selling Ford models in 2026.
By Joe Kucinski | 2026-07-06 16:48:56
10 Times the Ford Super Duty Let Us Down
Slideshow: 10 times the Ford Super Duty let us down.
By Joe Kucinski | 2026-07-01 07:42:10
F-150 Raptor R: The PROS & CONS of Daily Driving a Super Truck
Slideshow: the best and worst parts about daily driving an F-150 Raptor R
By Michael S. Palmer | 2026-07-01 07:35:47
