Sponsored by: Real Truck
Will it hold?
Old Aug 18, 2005 | 12:18 PM
3CRanch's Avatar
3CRanch
Will it hold?
Quick question:
I have an '04 F350 KR w/ 6.0L, FX4 package, long bed, etc, etc, etc. I need to transport 44 boxes that weigh 50 lbs each (batteries) across town.
Will my truck hold it?
Old Aug 18, 2005 | 12:22 PM
sdpj's Avatar
sdpj
ohhh yeah, only 2200 lbs
Old Aug 18, 2005 | 12:36 PM
gp42gpw's Avatar
gp42gpw
no problem at all you are not near your max payload I think the 05 payload is near 4,000lbs so 2,200 should be no trouble.
Old Aug 18, 2005 | 12:58 PM
3CRanch's Avatar
3CRanch
Just for clarification, this load will be placed in the bed, not on a trailer or whatever.
(I'm not with my truck right now or I'd just check the door jamb for the specs )
Old Aug 18, 2005 | 02:23 PM
gp42gpw's Avatar
gp42gpw
I did a quick search on the web (keep in mind the internet sometimes lies) but the payload for a CC4x4 6.0 was 4000lbs that's in the bed payload.
If this will help you at all I took 2200lbs of shingles a few weeks ago and it was no trouble at all that came in at around 2200Lbs 37 bundles. I say go for it but drive like you have a ton in the back and you will have no troubles.
Good luck
Glen
05 F-350 4x4 Reg Cab PSD 6Spd.
Old Aug 18, 2005 | 02:31 PM
scole250's Avatar
scole250
You still have "E" load rated tires, right? Make sure they're full, 65psi ought to be enough (somebody chime in if it needs more). Give yourself plenty of stopping distance.
Old Aug 18, 2005 | 02:45 PM
3CRanch's Avatar
3CRanch
E Rated? Dunno...I upgraded 'em to BFG AT's when I bought it (the stock ones looked wimpy )
Stopping distance? Not a problem there...I pull my boat and tractor often and give lots of room by habit.
I spoke w/ my mechanic (from the dealer) and he agreed that it should be no problem.
Old Aug 18, 2005 | 03:24 PM
scole250's Avatar
scole250
"D" load range tires are 8 ply and are usually rated for 2,500-3,000lbs per tire at 65psi. "E" load range tires are 10 ply and are usually rated for 3,000-3,500lbs per tire at 80psi. The max load varies tire to tire. As long as you have "D"s or "E"s and have the tires inflated enough for a 10,000lb load.
Just through the question out because I know folks that buy the cheapest tires they can find without consideration for what they want to do with their vehicle. They're the type that would try to haul a 10,000 load on retreads with 35psi in the tires and then scratch their head when the tire failed or turned the corner and broke the bead.
Old Aug 18, 2005 | 03:29 PM
jackofalltrades's Avatar
jackofalltrades
Actually, the BFG's for load, were a down grade from the E rated tires that came on your truck. (And I love BFG's, so don't go there. I'm not aware of an E rated BFG.) But, you're still well within the rating of those tires and payload of the truck. It won't even be like towing your boat. Maybe a little lighter on the steering wheel and a bit of pitch forward and down when you hit the brakes, (that's a lot more than what boat or trailer tongue weight would feel like), but well within what the truck can handle. It'll actually haul more than twice that weight in the bed. Be sure to distribute the payload well. Evenly across the bed, and if the last row of batteries is only a partial row, put them forward. Not in the farthest rear part.
-Steve
Old Aug 18, 2005 | 03:47 PM
tvsjr's Avatar
tvsjr
The truck will handle it fine. Remember that objects in motion tend to stay in motion, including in the event of a rapid deceleration accident. Strap those boxes down well.
Old Aug 18, 2005 | 10:10 PM
3CRanch's Avatar
3CRanch
Cool, thanks all.
Now I just have to wait for the shipment to arrive.
