I'm A Newbie Here So Please Bear With Me.i Have A 85 F250 Xcab And Can't Seem To Find The Cable That Hooks To The Vent,defrost,a/c,floor,control Lever.the Temp Cable Is Hooked Up,but No Selecter Cable.where Does This Cable Hook To?this Is A Great Site With Tons Of Very Usefull Info.thanks For Any And All The Help You Can Give Me.
If your truck has AC, there is only one cable. The vacuum hoses control the function. There is a place on the back of the control unit where it appears another cable should mount, but this is because Ford used the same control unit for AC & non-AC trucks. If you're having problems with the function selector, it's most likely vacuum-related.
"SMACUSTOMS"
Welcome to Ford Truck Enthusiasts. We are glad you chose to visit our site. In order to make it easier to navigate please read the following.
Please view the main forum page to find the best forum to ask any Technical questions
Also, below some of the titles of forums there is text that explains what the forum is either for or what shouldn't be posted in it.
Then ,Inside certain forum's there could be a Read First: thread or threads attached to the top.
Please read these threads before posting.
In Addition to the Tech Forums all user's can make their relationship closer to others by visiting & joining the State/Province Chapter that relates to their location.A complete list of Chapter's is located on the main forum page, near the bottom.
Once again...Welcome to the FTE Family
If you have mistakenly made a post you have 60 minutes to edit it.
If the 60 minutes has passed,you may contact the moderator of the forum to ask that the thread be moved to the proper forum.
