not the blower
Old Aug 17, 2005 | 08:51 PM
Scottbmt's Avatar
Scottbmt
not the blower
I have a ford expl 1994 and the blower keeps turning off at random will stay off for different durations of time. replaced the blower moter and wheel did not help.. any advice would be great.
Scott
Old Aug 18, 2005 | 05:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Scottbmt, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 19, 2005 | 10:49 PM
SmokyOlFord's Avatar
SmokyOlFord
Weak ground connection, bad wire or connector, fuse not all the way in or weak, switch bad. Does it happen at all fan speeds? The speeds may have resistors for each wired in there somewhere or it may help narrow down which wire.
-Smoky
Old Aug 19, 2005 | 10:55 PM
Scottbmt's Avatar
Scottbmt
Blower Not Right
It does it on all speeds, taught about changeing the reister but not sure.
Old Aug 19, 2005 | 11:42 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Sounds like a bad connection, ground or hot side.
Old Aug 20, 2005 | 06:00 PM
Holmesuser01's Avatar
Holmesuser01
The speed resistor block has a small thermal switch on it. They often go bad. It is usually installed on the engine side of the heater box near the blower motor.
