Modular V10 (6.8l)
Help regarding Fuel venting system
Old Aug 17, 2005 | 06:56 PM
Fords For Ever's Avatar
Fords For Ever
Just got back from the Stealership (read Meron vs Mercon V in Superduty forum) and asked that they check the fuel tank vapor carbon canister system for the THRID time under warranty. Inside and outside of my truck, on warm days, you can occasionally smell gasoline odors. Thanks to this forum I learned that there is a carbon canister above the front left wheel well. Nobody else that I know of with a 99 or newer gas powered truck F250 has this problem. I thought that someone posted that this fuel vent system is under about 2 psi and asked the stealership to check the PRV or whatever else could cause a release of vapors. Well, they said the system is freely vented and there is nothing they can do. Because of their help with my tranny (other post mentioned) I may ask them to replace the carbon canister. I do not overfill my tank and this problem has occured since the first summer I owned my truck. Anybody else have this problem or does anyone have any advice?. My Haynes manual does not even mention the canister but shows it in a photo. BTW, searched this forum first for the Mercon Vs. Mercon V info. Very helpful as usual. Bye, have to call for a tow truck.
Old Aug 19, 2005 | 10:18 AM
rlh68050's Avatar
rlh68050
The fuel vapor canister (charcol canister) is a buffer that stores fuel vapors that build up in the system during normal operation. At times the PCM will command the VMV (vapor managment valve) to open and PURGE vapors from the canister back into the intake. There is another valve on the canister inself called the CVS (canister vent solonoid), it is normally open, but NOT to vent fuel vapors to atmosphere, there is a check valve to prevent that. It needs to be open so when the VMV is pruging vapors back into the intake using vacumm, the tank isn't sucked in and colapsed. It only is commanded closed when the PCM preforms an OBDII PURGE monitor test which looks for fuel vapor leaks. I suspect that the check valve is bad on or near the CVS, and what you are smelling is vapors from the canister that are escaping. NEVER, under normal operation will raw fuel vapors be vented to atmosphere.
Old Aug 20, 2005 | 12:33 AM
NoMo's Avatar
NoMo
There may be a second vapor recovery system back by the fuel tank too. Make sure they check both.
Old Feb 8, 2006 | 12:07 PM
Fords For Ever
Follow up - Just before my truck went out of warrenty I thought I'd bring it in for the fourth time to solve the gasoline odor problem. Thanks to the informative post above I had confidence something was wrong (actually made the service manager read it). This time they found it, the vapor vent line leading to the carbon canister had a cracked (pushed in) fitting at the canister. Replaced the fitting/canister and problem solved. The senior mechanic who worked on it said in all fairness to others that attempted to fix it that it was not easy to find and that he got lucky. Boring post, yeah, but I'm glad it's fixed. Thanks guys.
Old Feb 8, 2006 | 12:46 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Another BS story from a dealership tech.
My '01 (granted, that might be different than your '99, but I seriously doubt it) has the Evaporative system pressure test "bung" right there under the hood.
That's so they can hook up a leak tester to pressurize the system (w/smoke machine?), and check for leaks. If they had done that, they would have found the problem, or at least that you were not crazy and you DO have a leak
Amazing...
Old Feb 8, 2006 | 01:09 PM
Fords For Ever
krewat, I are right on the money as usual. This service manager, at least the third one in 3 years, was very helpful and mentioned he would have a smoke test performed. Evidently common knowledge to some people but then how come they never did it on the first three tries. It is a PITA to take time off, drive down and wait/kill time when it seems they don't really try or care to solve the problem. A good mechanic is hard to find and worth paying for.
Since this problem should have been diagnosed sooner and the fact that they put mercon V in my tranny I have very little faith in that or any dealership.
Old Feb 8, 2006 | 01:46 PM
krewat's Avatar
krewat
I sometimes wonder if they get paid for an hour's worth of time to look at something and "not find anything" otherwise, wouldn't they WANT to find something wrong and at least throw parts at it?
Makes me wonder sometimes...
Good luck with it in the future!
alchemist1
17
Mar 18, 2020 07:24 AM
737ngdriver
Jun 8, 2015 02:05 PM
TheRedBeast01
Modular V10 (6.8l)
Jun 30, 2014 11:09 AM
athenshome
Sep 25, 2013 11:25 PM
JonathanE
Feb 26, 2012 08:04 PM
