i hear a whine whenever i start off from a stop or when the tranny is in 1st gear only, it immediately goes away after it shifts into 2nd...is this normal? do they all make this sound? newbie hear-looks like a wonderful site by the way....
This is a pretty common problem on Chevrolet trucks and vans with the 4L80E transmission (TH400 w/overdrive). First gear howls like a banshee, second gear not as bad and third it's gone.
I have replaced NUMEROUS output carriers/sun gears in these transmissions due to improper machining marks on the gears. I can't vouch for Ford, but it sounds to me that you have a similar problem on your hands, although with the Chevys, it's not a big deal, just noisy. Have your dealer check it out, man!!
