1978 - 1996 Big Bronco
What Are Some Ways You Have Improved Gas Mileage?
Old 08-20-2005, 05:56 PM
Hamfisted's Avatar
Hamfisted
Hamfisted is offline
Wax it !
A good wash and wax job will help reduce the air drag going down the highway. I wax mine every 2 or 3 months.
Mike
'96 5.8L EB
Old 08-21-2005, 12:07 AM
jcp123's Avatar
jcp123
jcp123 is offline
Mike
'96 5.8L EB
that has to be a myth, right? Like blinker fluid
Old 08-21-2005, 12:26 AM
azjan's Avatar
azjan
azjan is offline
I get better milage with name brand gas. (Chevron). I get pinging with am/pm gas. Arizona.
Old 08-21-2005, 12:53 AM
jcp123's Avatar
jcp123
jcp123 is offline
Strange, my '68 Mustang always ran strong on the Arco gas. (AM/PM stores are at the Arco stations, so I presumed that's what you meant)
Old 08-21-2005, 05:48 AM
imlikeojnow's Avatar
imlikeojnow
imlikeojnow is offline
Smog pump, and and Ac delete bracket. Tune Up, timing set, tire pressure, electric fan, and dont drive just to drive
ken
Old 08-21-2005, 10:12 AM
scurbiedog's Avatar
scurbiedog
scurbiedog is offline
Buy the wife and kids a bus pass!
Old 08-21-2005, 03:08 PM
CR250Bronco's Avatar
CR250Bronco
CR250Bronco is offline
what is this seafoam and what does it do? where can i get it? sounds pretty nice
Old 08-22-2005, 10:23 AM
Floridaboy's Avatar
Floridaboy
Floridaboy is offline
Here is a thread I found
https://www.ford-trucks.com/forums/s...hlight=seafoam
I called Advanced Auto Parts (formerly Discount Auto Parts) and they have it stock.
Old 08-22-2005, 01:27 PM
Redbob's Avatar
Redbob
Redbob is offline
Very specific suggestions for '78s:
Get a '79 distributor, and set it to about 12 degrees advance; you'll get some pinging at part throttle (10 - 6 inches Hg vacuum) but it will go away at full throttle and at highway cruise.
Plumb the distributor vacuum hose direct to the manifold - no restric tors or delay valves.
Get rid of the EGR.
Lean out carb main jets - your carb is jetted for "driveability" not economy.
These are good for 1.5 - 2 mpg.
General suggestions:
Run with the A/C off - that's worth .5 - 1.0 mpg
Be skeptical about any "mouse milk" you add to your gas tank, pour into your engine, etc. that claims to increase mileage. When in doubt check it yourself by carefully measuring every gallon you pump into the tank.
Old 08-22-2005, 04:41 PM
poffutt's Avatar
poffutt
poffutt is offline
cut a piece of 2x4 wood that will fit under your gas peddle. Make it to only alow 1/2 throttle. You will save allot of gas that way. Sounds like a joke, but it really might work.
Old 08-24-2005, 12:21 AM
jcp123's Avatar
jcp123
jcp123 is offline
Have been driving carefully and filled up today. I've been getting 13.49mpg on city-only driving by accelerating smoothly and making the engine stay under 2000rpm, with just three lapses in that discipline in the 108 miles I measured last tank (only got it a quarter down before filling and checking). That's already better than the EPA estimate for city-only driving (they said 13), so for sure that's worth a try.
Next, I'll air up the tires to specs, maybe a pound or two extra, and see where that takes me.
And then I'll change plugs and wires, and calculate again.
And then lastly, I'll run some seafoam through the motor, oil, and gas tank and see how that goes.
Eventually, I'll also ditch the old lady exhaust and strap some cherry bombs on that mamacita, and see what that nets as well.
Old 08-24-2005, 05:04 AM
b4hntn's Avatar
b4hntn
b4hntn is offline
Use oil no heavier than 10W-30.
  #28
Old 08-25-2005, 03:28 PM
roostercrows's Avatar
roostercrows
roostercrows is offline
Smile
ok i just installed a k&n intake system on my bronco and have noticed a significant gain, i also plan on putting a 3" cat-back exaust on as i have been told by many that not only will it increase fuel mileage but power as well, last but not least 2 days ago i found a little product called the fuel genie and it garentees mileage increase or your money back so i may give that a try too, just type in fuel genie in a search engine and you will find it. hope that helps
  #29
Old 08-29-2005, 11:52 PM
1987_f150's Avatar
1987_f150
1987_f150 is offline
Dont drive at all...taxi or bus...best way to save =)
  #30
Old 08-30-2005, 05:51 AM
Beast12's Avatar
Beast12
Beast12 is offline
My friend drives his Ranger back and forth to work instead of the Bronco.
-Matt
Quick Reply: What Are Some Ways You Have Improved Gas Mileage?
