Engine cranks,no start
Old Aug 17, 2005 | 01:15 PM
lrodptl's Avatar
lrodptl
97 Ranger 2wd,2.3L- This week after 8 years I changed my battery,battery harness,starter relay,starter/solenoid assembly. The engine would not crank to begin with and then during the repair everything I touched broke. Now everything is in, the engine cranks but no start. I pulled a plug and it smelled of fuel. IT seems I'm getting fuel but no spark.Thanks for the help.
Old Aug 17, 2005 | 04:01 PM
ovalholic's Avatar
ovalholic
Did you check for spark? Was it running before it stopped cranking or did over cranking kill it? I would check the connections for the harness and ground wires. Also, check your fuses, you may have shorted something during the install.
Old Aug 27, 2005 | 11:55 AM
lrodptl's Avatar
lrodptl
Found alternator seized.
