Squeaking from front
Old Aug 16, 2005 | 07:11 PM
ExMan01's Avatar
ExMan01
Cool Squeaking from front
Ever since I've owned my 2001 Expy, there has been a constant squeaking noise, that sounds like it's coming from my front left wheel. It sounds like a thin wire rubbing on the rotor, it's real weird and very annoying. I've already replaced the ball joints on that side and the brakes are new, any thoughts?
Old Aug 17, 2005 | 07:28 PM
High_Horse's Avatar
High_Horse
Possibly a wheel bearing, especially if its dry....does it do it all the time or during specific movement? Does it do it if your moving slow or fast or either? If during slow movement, take the wheel off and spin the hub by hand to try to trace it.
Do you have those brake pads with the "crickets" on them? The one that let you know when the pads are low, they may be out of adjustment?
Old Aug 17, 2005 | 11:26 PM
ExMan01's Avatar
ExMan01
It mainly does it at slow speeds, up to around 30 mph. The brakes are about 3 months old and it's been making this noise from the get go. If it is dry can I just pack some more grease in there I guess, and how hard is is to do? I'm thinking about just replacing the wheel bearings all around, is this something I can do with regular tools or do I need special tools.
I'm convinced that the stock mechanics on newer vehicles suck ***. Too bad, I love my Expo
Old Aug 18, 2005 | 12:14 AM
High_Horse's Avatar
High_Horse
Well, on a 4x4 I can't help ya with disassembly....you'll have to snag a Haynes manual (about $15 at Autozone) ....or maybe Monsta will chime in here and enlighten us?
Packing a bearing is easy, if its good! You can buy one of those bearing packers that looks like a plastic funnel with a grease fitting, I have one, works well. But you'll need to check the "race" for nicks and that the bearing isn't loose (worn). The Haynes book or equivelant will be helpful on that.
Old Aug 18, 2005 | 12:37 AM
bruce381's Avatar
bruce381
The rear axle bearings are oil lubes and not greaseable, the front on the 4wd anyway are not servicable. could be E brake out of adjustment?
Bruce
Old Aug 18, 2005 | 11:41 AM
amm888's Avatar
amm888
the front wheel bearing assembly simply pulls off and is replaced as a whole - you just need to pull the wheel and a sensor (at least on 97-02)
Old Aug 18, 2005 | 08:21 PM
mike02expe's Avatar
mike02expe
I agree with the bearing assembly...... Not hard and not too expensive if you pull a shadetree job...
Kicker456
2004 - 2008 F150
Nov 28, 2016 03:14 PM
93-331-29PSI
6.7L Power Stroke Diesel
Sep 28, 2015 03:32 PM
AkF250HD
Aug 7, 2013 06:31 PM
spdmpo
13
May 28, 2010 10:17 PM
Rob04
Nov 2, 2006 01:46 PM
