Sponsored by: Kumho
Odd brake behaviour
Old Aug 16, 2005 | 05:20 PM
Torstein's Avatar
Torstein
Odd brake behaviour
Since I bought my van a couple of year ago it has had a strange behaviour while braking.
1) When pressing the pedal, it starts a good retardation.
2) When continuing to increase the pedal pressure, the brake effect more or less goes away (or at least it feels like).
3) Still continuing to increase the pedal pressure, the brake effect comes back and gives a good stop.
* The rear brakes are properly adjusted.
* The pedal has a resonable hight(starts the retardation long before 1/3, and the pedal stops before 2/3 of travelling length)
* No yellow rabs light.
* No red brake light.
* The van may occationally pull a bit when the brakes are applied, but I guess thats another story, or maybe normal. Nothing scaring here.
* The rabs does its work on slippery surface.
* If rabs is deactivated, I get a very good stop but the rear weels may get blocked
* The pedal may perhaps have a slow return, not certain what's normal here. Doesn't feel like a problem.
Does anyone have any experience here?
Thanks!
Torstein
E350 '93 7,3 Diesel IDI E4OD RABS II Oslo Norway
170 000 km and counting
Old Aug 21, 2005 | 09:11 AM
Torstein's Avatar
Torstein
Could it be the master cylinder?
Old Aug 21, 2005 | 09:12 AM
Amtek's Avatar
Amtek
You should bleed the brakes, there may be air in the system
