oe tcs where
Old Aug 15, 2005 | 11:15 PM
broke man's Avatar
broke man
oe tcs where
where can i find a good oe tcs
can i install it myself
what else should i look at before assuming this is the culprit
actron code 653 says tcs did not switch during test a0de/w1995 f150 5.0
Old Aug 16, 2005 | 11:28 AM
andym's Avatar
andym
What is a tcs? I've been working on Fords for a long time, and I've never heard of that part. Is it known by another name? Do you mean tps?
Old Aug 16, 2005 | 11:44 AM
EPNCSU2006's Avatar
EPNCSU2006
Torque converter solenoid?
Old Aug 16, 2005 | 11:31 PM
MemOrex's Avatar
MemOrex
Transmission control switch. What's the problem with the truck? Transmission problems?
Old Aug 17, 2005 | 06:49 AM
broke man's Avatar
broke man
transmission control switch- truck loses torque at highway cruising speeds maybe its shifting down. when this happens at 60 mph on road engine revs if i dont get foot off accelerator and torque suddenly comes back tranny slams back into gear feels like i got rear ended by a vw.actron code scanner gave code 653 -tcs did not switch during key on engine running self test. where is switch located?
Old Aug 17, 2005 | 01:31 PM
quicklook2's Avatar
quicklook2
call or go to a ford dealer.
i assume you have a e40d, i looked at diagram part list and did not see your tcs listed.
Old Aug 17, 2005 | 01:50 PM
broke man's Avatar
broke man
quicklook
aode/w
aode/w
Old Aug 17, 2005 | 02:01 PM
quicklook2's Avatar
quicklook2
Originally Posted by broke man
aode/w
aode/w
do you really mean 4r70w?
anyway, tcs is the switch on the gear shift lever.
Old Aug 17, 2005 | 02:25 PM
broke man's Avatar
broke man
i think 4r70w and aode/w are same transmission .the tag on side of tranny reads aode/w.im going to shop to have their big scanner check it out. i will post their results when i get back.
Old Aug 17, 2005 | 02:36 PM
quicklook2's Avatar
quicklook2
i seem to remember that a post said that the wiring to the button is very fragile.
i do not feel good today and i am thinking a little slow. too much partying last night that is why if missed your first reference to trans. model.
Old Aug 17, 2005 | 03:41 PM
broke man's Avatar
broke man
took to shop ran through snap on scanner.he said soelinoid was going bad and said it was an aode service bulliton/recall issue .said ford had been saying that soleinoid had problems and to switch it out with improved solenoid.$400-$500 parts and labor. i had taken it to another shop who said i needed a full rebuild after taking it on a road test but with no scan .i thought that was a load of crap as the truck only has 83500 miles on it.ihave been told that the aode tranny is a good strong transmission . am i right or wrong? i had hoped for 150000 miles out of it before any major overhauls. i take good care of my vehicles.this is totally over my head and i dont want to get ripped off!
Old Aug 17, 2005 | 04:06 PM
quicklook2's Avatar
quicklook2
call your district ford office about recall. you may get lucky.
