Torqueshift
Old Aug 15, 2005 | 10:43 PM
ikold's Avatar
ikold
Torqueshift
Just picked up an 04 f350 and was wondering if I have the Torqueshift transmisison or not? Did all 04's with the 6.0 in the f350 have the Torqshift trans?
Old Aug 16, 2005 | 01:04 AM
Hayapower!'s Avatar
Hayapower!
If you don't have a 'clutch pedal', you have the Torqshift/5R110...
...............HP.......................
Old Aug 16, 2005 | 10:13 AM
WWBeast's Avatar
WWBeast
Hayapower is right you have one if its an auto
Old Aug 16, 2005 | 06:03 PM
Bigham's Avatar
Bigham
You have the torqshift with an automatic
Old Aug 17, 2005 | 08:16 AM
jasonschwenk's Avatar
jasonschwenk
and '03?
does that go for '03s as well ?
how about a bulletproof rebuild kit for them anyone heard of one?
Old Aug 17, 2005 | 09:44 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Yes, all 6.0l's came with the Torqshift - I would hate to see a 4R100 behind one...
There are a couple of people that do rebuilds for them, but aside from niggles (and a recall) they are a pretty darn strong unit standard.
Old Aug 17, 2005 | 12:48 PM
PSD6litre40's Avatar
PSD6litre40
I had one that was under recall, I blew the side of the case out of mine!
Old Aug 17, 2005 | 12:59 PM
RedRage's Avatar
RedRage
That was part of a recall. A small washer lets go on one of the clutch hubs. The trans itself is a very stout unit. The 110 in the name 5r110 is the torque rating, 1100 ft/lbs of torque. There are no bands in the trans to burn up, at least not in the usual sense.
Joe
Old Aug 17, 2005 | 01:08 PM
PSD6litre40
The weakness is the Torque converter......
Old Aug 17, 2005 | 02:37 PM
Casey's Avatar
Casey
Are there some unusual sense bands in there? Just wondering....
Old Aug 17, 2005 | 03:20 PM
ikold's Avatar
ikold
Does anyone make a good replacement torque converter for the torqshift?
Old Aug 17, 2005 | 05:38 PM
Todder's Avatar
Todder
You would be having to be adding a ton of power to justify buying a new torque convertor for the TS. Stock does just fine. I think new clutch packs would be a better buy than a torque convertor.
Old Aug 17, 2005 | 05:43 PM
BigF350's Avatar
BigF350
FTE Emeritus
Are you sure with this?
The name of the transmission (as far as I am aware) is
5 - the amount of effective gears in the transmission
110 - to denote that it is a step beyond the 4R100
The fact that the Torqshift isn't available in the F650 and up, confirms my opinion that in fact it isn't rated at a whole lot more than 600/650lbft.
Old Aug 17, 2005 | 05:48 PM
Todder's Avatar
Todder
The F650 is a 2 1/2 ton truck. No full size truck tranny will go in there. Something much heavier.
Old Aug 17, 2005 | 06:36 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Absolutely...the stock converter is stout.
Under high torque situations, the direct drive clutch packs and the (igornantly engineered) inverse-proportional solenoids controlling the direct drive gear and EPC end up failing and taking other parts with them.
