Sponsored by: Auxito
Intake manifo problems!!!
Old Aug 15, 2005 | 07:33 PM
sailorman3's Avatar
sailorman3
I'm repairing a98 F-150 with a 4.6 engine and I've run into a bit of a problem. This truck had a leaking head gasket. I've striped the engine down and put the heads in to be checked. When I went to pick the heads up today, I was told that one of the heads has to repaired. They told me that the antifreeze has corroded a small section by one of the intake holes. I looked at what they showed me and it doesn't look to bad to me. If I put some high heat RTV on this section with the new gasket, will this give me a good seal or should I bite the bullet and buy a rebuilt head or repair this one. My gut feels that the RTV will be OK but we are taking vaccume leaks here. Any help soonest would be great. Thanks in advance,
Sailorman3
Old Aug 16, 2005 | 12:54 PM
l-m tech's Avatar
l-m tech
i use a thin coat of rtv sealer on the heads that have errosion on the coolant passages a lot,just dont use it on the ports that feed the cylinders.
7622RM
1983 - 2012 Ranger & B-Series
May 27, 2014 08:33 AM
carriljc
1978 - 1996 Big Bronco
Dec 16, 2012 11:19 AM
Tomget
27
Oct 3, 2010 10:54 AM
staysbroken
Dec 22, 2005 01:22 AM
Kanute
Aerostar
Mar 4, 2005 12:11 AM
