Hard to start after sitting
Old Aug 15, 2005 | 02:55 PM
t-bird1963's Avatar
t-bird1963
I will try to make this as short as I can. I have a 90 f150 with the 4.9. In the morning or after the truck sits I have to let the fuel pump run for almost a half hour before it will start. If I try to start it before the fuel pump turns off on its own it wont run. I replaced the back tank pump and it now just pushes the fuel to the front tank. I noticed there is no return line to the back tank. (great) So where should I start?
And thanks to everyone that helped with the cluck problem.
Old Aug 15, 2005 | 10:17 PM
LxMan1's Avatar
LxMan1
Sounds like the tank switching solenoid is not shifting all of the way. There should be a return line that comes from the switching solenoid on the frame.
Old Aug 16, 2005 | 07:44 AM
t-bird1963's Avatar
t-bird1963
I tried to find that switch but cant. Where can I find a picture of it?
Old Aug 16, 2005 | 04:53 PM
LxMan1's Avatar
LxMan1
Is there a part hanging on the frame behind the high pressure fuel pump that has 6 lines going to it?
Old Aug 17, 2005 | 09:06 AM
t-bird1963's Avatar
t-bird1963
This year truck dont have an external fuel pump. I followed the lines and I dont see any valve or anything that could be a valve.
Thanks
Old Aug 17, 2005 | 09:04 PM
LxMan1's Avatar
LxMan1
Ok, then it has check valves in each pump assembly. One tank may be pumping into the other. These are known to fail.
Old Aug 18, 2005 | 08:55 AM
t-bird1963's Avatar
t-bird1963
So then my best bet is to change the front tankis pump also? Man that stinks.
Old Aug 21, 2005 | 02:27 PM
LxMan1's Avatar
LxMan1
It could be the only way repair it.
Old Aug 22, 2005 | 07:35 AM
t-bird1963's Avatar
t-bird1963
Well that stinks. Does anyone have a photo of the valve?
Old Aug 22, 2005 | 05:43 PM
LxMan1's Avatar
LxMan1
The check valves are inside the plastic housing. I've never broken one open to look at it.
Old Aug 23, 2005 | 07:41 AM
t-bird1963's Avatar
t-bird1963
I know this may sound stupid but which plastic housing are you talking about? Pump housing?
Old Aug 31, 2005 | 02:02 PM
t-bird1963's Avatar
t-bird1963
just a bump to see if anyone has figured this out yet.
Old Aug 31, 2005 | 10:55 PM
LxMan1's Avatar
LxMan1
Yes, the pump housing. Sorry, I've been away from the PC longer than I wanted.
