Fuel Tank size?
Old Aug 15, 2005 | 01:35 PM
GoldenRanger's Avatar
GoldenRanger
Fuel Tank size?
what is the standard size of a 2000 ranger's fuel tank.
im thinking its 16.1 or so....can anyone tell me? Im trying to calculate gas milage. thanks.
Ian
Old Aug 15, 2005 | 10:13 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
That probably won't help you much. You need to fill it up until the pump clicks off. record the mileage, drive it until it's time to refill. Fill the tank until the pump clicks off again. Then divide the miles traveled, by the gallons used. This will be the most accurate MPG reading. Say you went 200 miles and used 10 gallons. That would be 200/10=20mpg
If you go to the specs at the top of the main forum page, you can look up all of the specs on your truck.
Jimmy
Old Aug 18, 2005 | 07:39 AM
ovalholic's Avatar
ovalholic
The EPA has a site also for all vehicles...
http://www.fueleconomy.gov/
