read end ratio
Old Aug 15, 2005 | 11:44 AM
learpilot's Avatar
learpilot
read end ratio
I have an aod in my 56 f100 , the rear end is (?) , But I did what I recently saw in another post and raised one wheel and rotated it 10 times which produce 13.75 revolutions of the pinion gear. Divided by 5 this gives me a ratio of 2.75. Is this the "rear end ratio or as Randyjack said the final ratio or is there a difference? Can someone tell me if this setup is going to result in an acceptable preformance as far as low end and a decent high speed cruise. BTW the truck will have a 351w in it. Thanks guys
Old Aug 15, 2005 | 12:04 PM
concretegarage's Avatar
concretegarage
Ford AOD (not wide ratio) gearing seems to be as follows
2.40, 1.47, 1.00, 0.67
With a rear end of 2.75, the final factor is going to be your wheel&tire diameter
Assuming a diameter of ~28" and a locked up torque converter you will be doing 70MPH (6160 ft/min) at ~1555 RPM (unless I messed up with the calculator somewhere)
BTW: wheel speed would be 844 RPM, driveshaft speed 2321 RPM
You ought to get decent mileage
Old Aug 15, 2005 | 12:14 PM
Jag Red 54's Avatar
Jag Red 54
IMHO, this seems a little tall. The AOD should handle your top end speed. I would think that most people will suggest 3.25 - 3.50 gears. But, I would try it out first and see how you like your take-off speed. Then, after you have driven it a while, change the ratio as necessary. Good luck, Jag
Old Aug 15, 2005 | 12:19 PM
concretegarage
I would agree with Jag, its probably a bit tall for most performance minded people
Old Aug 15, 2005 | 01:50 PM
LEckart's Avatar
LEckart
If you want low end performance you will probably need somewhere between 3.50 to 4.11 and with the AOD you should still get decent hiway rpms. I believe most newer autos run about 2200+/-rpm at 70mph with the AOD.
Old Aug 15, 2005 | 04:12 PM
Okiedokie's Avatar
Okiedokie
I am using the original 3.92 rear end in my 53 with AOD/302. It performs well on enthusiastic starts, makes me happy with the 302. On leisurely starts, it seems to shift too early and "bogs". I am thinking 3.25 will be better, and am looking for replacement rear end. Joe
Old Aug 15, 2005 | 04:15 PM
Okiedokie's Avatar
Okiedokie
My rear tires are 30" and I am pretty sure that at 75 mph I was turning 1850 rpm. If I get a chance to drive it this week I will write it down. Joe
Old Aug 15, 2005 | 04:16 PM
learpilot's Avatar
learpilot
I probably will try it as is but just wondering what is involved in changing this ratio, does it mean a new rear end or can the gears be changed? Thanks for all the good info,Jerry
Old Aug 15, 2005 | 04:21 PM
LEckart's Avatar
LEckart
You just have to change the center section(third member/ pumpkin), but you have to make sure your new third member takes the same axle spline as your current rearend. They are either 28 or 31 spline.
Old Aug 15, 2005 | 04:22 PM
LEckart's Avatar
LEckart
I assume we are talking the Ford 9" rearend??
Old Aug 15, 2005 | 05:23 PM
4tl8ford's Avatar
4tl8ford
Gas is rapidly approaching $3.00 gal nation wide.
At that price low end performance would have to take a back seat.
Old Aug 15, 2005 | 10:48 PM
AXracer's Avatar
AXracer
You can just change the ring and pinion gear set in the center section, but you'll need someone who knows how to set the proper lash. Fortunately with all the racers running Ford 9" rears there's probably someone local with experience. Check at the closest speed shop or circle track. The popularity of the 9" also means you have one of the largest selections of ratios at reasonable prices available from high 1's to high 6's.
What's right for you is like asking what color should you paint your truck. What engine mods if any, what size tires, how much load you going to carry. Do you want to smoke the tires from gas station to gas station or are you going cross country interstate cruisin? Etc. etc etc.
Old Aug 16, 2005 | 09:29 AM
Jag Red 54's Avatar
Jag Red 54
I had a set of 3.50s in my 9" when I got it. I'm running a c-4, so the engine rpms were high on the freeway. Daryl sold me a good set of 3.00s for cheap ($25). I had them installed by the local rearend guru as I was not sure that I could get the proper setting. It runs great on the freeway and will still burn the tiresmam little on takeoff. Jag
Old Aug 16, 2005 | 10:07 AM
Randy Jack's Avatar
Randy Jack
Jerry -
Try this website. It lets you change ratios, etc to find out what rpm you'll be running. Use 0.67:1 as the final drive ratio of the AOD, then plug in the various rear end ratios, tire size.
Might answer your questions...kinda cool.
http://www.car-videos.com/tools/speedrpm.asp
