Brake problem
Old Oct 2, 2002 | 01:36 PM
tbirdrief's Avatar
tbirdrief
Brake problem
I have a '76 F250 2X4 supercab.
The front reservior(for the rear brakes) goes empty(about once every two months or when I really need it).
In fact it leaks out the cover. I rebuilt the back brakes last spring and replaced the master about two years ago. The cover, seal and lip on the master seen to be O.K. Is there a reason for this pressure build up?
https://www.ford-trucks.com/dcforum/Images/firejump.gif
Thanks, Rief
Old Oct 2, 2002 | 03:23 PM
Mil1ion's Avatar
Mil1ion
Brake problem
The rubber seal in the M/C for the secondary circuit has failed and the back pressure from the other primary circuit is forcing fluid into it leaking around the cap then sucking it back out.
Check for leaks besides the M/C.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Oct 2, 2002 | 04:25 PM
dfisher1's Avatar
dfisher1
Brake problem
Old Oct 2, 2002 | 07:01 PM
theonlybull's Avatar
theonlybull
Brake problem
interesting.. our 79 c-30 chebbie cube van just started doing that... not a good feeling when the peddle goes to the floor with 12,000 lbs behind ya..
Old Oct 2, 2002 | 09:43 PM
tbirdrief's Avatar
tbirdrief
Brake problem
There are no leaks in the rest of the system. Does
it sound like I need to replace the M/C?
Would the compensating valve have something to do with it?
Thank you,
Rief
Old Oct 3, 2002 | 12:12 PM
dfisher1's Avatar
dfisher1
Brake problem
tb,
Replace that Master Cylinder before you get yourself killed!
And, oh yeah, have a nice day,
KingFisher
