No clue
Old Aug 14, 2005 | 06:31 PM
blue ranger's Avatar
blue ranger
Question No clue
I have a 90 ranger 2.3 that seems to have a mind of it,s own lately. About a mounth ago it started pouring black smoke out every once in a while, now it seems to be getting worse. I did the normal things like clean Maf, fuel regulator was changed last year,checked for vaccum leaks the whole works. I pulled KOEO codes an got 33,41,66,88,95 any suggestons to what could be the problem .
Old Aug 14, 2005 | 08:05 PM
ColonyPark's Avatar
ColonyPark
Have you checked the PCV valve?
Old Aug 14, 2005 | 08:11 PM
blue ranger
No i have not ,but will a bad pvc valve cause this. Also since it has been almost a year could it be a bad pressure regulator.
Old Aug 15, 2005 | 09:57 AM
ColonyPark's Avatar
ColonyPark
I'm not a professional mechanic, so this advice is worth what you're paying for it. :-)
A blocked PCV valve will cause increased pressure within the engine and can cause oil to go places you don't want it to.
CJB
Old Aug 15, 2005 | 11:00 AM
blue ranger
Thanks i will change the pvc valve an see what happens. I just finished changing the fuel regulator today so I will drive it to work and see if there is any difference.
Old Aug 15, 2005 | 01:41 PM
jinx102672's Avatar
jinx102672
I'm not sure if you found what your codes mean or not, but if they are OBD1 then here is what they mean.
O = KOEO
R = KOER
C = Continuous Memory
33 (R,C) EGR valve fault/ not closing properly
41 (R) HEGO/HO2S sensor voltage low/system lean
(C) No HO2S switching detected or sensor signal out of range.
66 (O,C) TOT sensor signal input below self-test minimum, or vane air flow circuit below minimum.
88 (O,C) Choke relay out of range or Dual plug input control failure or shift solenoid 3/4-4/3
95 (O,C) fuel pump secondary circuit fail.
