cab dome light
Old Aug 14, 2005 | 12:31 PM
crustydoughboy's Avatar
crustydoughboy
cab dome light
hi gang, I just bought a 97 ford ranger 3.liter. When i got it home i noticed the cab dome light wasn't working, i took off the cover, no bulb, easy fix, got a new bulb and now it works, as a matter of fact it won't go out most of the time. open and close the doors has no effect, start the truck and it still stays on. now i know why there was no bulb in it. I like having a dome light but i don't want to run the battery down, any ideas on how to fix it???
thanks
Old Aug 14, 2005 | 01:38 PM
JD717's Avatar
JD717
Just a simple question, but is the dome light switch on?
Perhaps its a short in the wiring somewhere, I dont really know for sure.
Old Aug 14, 2005 | 02:15 PM
crustydoughboy
dome light
yep it's on the dimmer switch but also seems to be on some kinda timer. cause cometimes it stays on for a few minutes and then sometimes it won't go out at all
Old Aug 14, 2005 | 02:44 PM
Bob Ayers's Avatar
Bob Ayers
Very common problem on Rangers. The dome light switches are located on the door latch assembly in the doors. Most of the time, spraying the latch liberaly with WD-40, then open & close the door several times will free these
switches up...
Old Aug 14, 2005 | 03:35 PM
pawpaw's Avatar
pawpaw
Bob is right about the WD-40, check out the 4 page thread on this subject, in this forums technical sticky, at the bottom, under "miscellaneous", ther good info here too, check it out, the dom light link is https://www.ford-trucks.com/forums/s...hreadid=105594
