Good Morning Everyone. This is my first post on the forum, but I have been reviewing some of the past threads and the information is really helpful.
I have a problem and hope someone can help me. I have a 2002 Explorer with 34,000 miles. Yesterday morning I drove the explorer normally. Then yesterday afternoon I went to start it and Nothing!
The Theft light is blinking faster than normal and I hear a clicking sound (when the key is out of the ignition) which appears to be coming from the relay box under the hood. I have swapped relays and the problem continues. I disconnected the neg. battery cable to reset the system, but no luck.
Also when I put the key in the iginition, I hear that same clicking sound and the dash gauges go crazy! I thought maybe it was the theft system, but I am not sure.
I am a novice with repairs but any thoughts or help would be appreciated.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Sounds like a dead battery. Have you tried jumping it or charging the battery? It you have the headlights on and turn the key, do the lights die or dim?
As I said, I'm a novice. You were right it was a dead battery. Apparently it had enough juice to run accessories. Glad it wasn't anything more serious, I've already had one tranny rebuilt and some o2 sensors replaced..
