1979 F-150
Old Oct 4, 2002 | 06:24 AM
boone6978's Avatar
boone6978
1979 F-150
I have a 1979 F-150 pictures are on here under user gallery boone6978. Im having trouble figuring my gear ratios. someone ripped the little tag of the housing on the 9 inch axle. and the calculator says i have 4.10 gears, cause i have 31 inch tires and at 60 mph i run about 2800 rpm's. funny thing is that the door tag says i have something like 2.75 gears (does this sound right?). is there any other way to find out for sure. Could this be a cab and box on a different frame? any help is appreciated greatly. Thanks Dan
Old Oct 4, 2002 | 09:05 PM
BUDD5670's Avatar
BUDD5670
1979 F-150
sOMEONE SOMEWHERE PUT ANPOTHER DOOR ON YOUR TRUCK, AND IT SOUNDS LIKE THAT DOOR CAME FROM A 2WD, AS THEY WERE THE ONLY ONES THAT HAD 2.75 GEARS IN THEM. cHECK YOUR FRONT TAG ON THE AXLE BY YHT DIFF COVER, THESE USUALLY DON'T GET TORN OFF, THAT SHOULD LET YOU KNOW WHAT GEARS THAT YOU HAVE. eric d>
Old Oct 5, 2002 | 09:43 PM
taz3fan's Avatar
taz3fan
1979 F-150
i would say you have a 3:50 ratio ,pretty standard ratio
Old Oct 6, 2002 | 01:09 AM
heathdaily's Avatar
heathdaily
1979 F-150
Just to let you know, if you've got 31-10.50-15 tires, they probably aren't 31" tall. That's what's referred to as a nominal size. You'll have to physically measure them if you want to know how big they are. Even a little bit can throw you're calculations off. I would only consider anything calculated off of you're tire diameter an estimate. Even putting it on a wider or narrower wheel will affect it's diameter.
Old Oct 6, 2002 | 01:32 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
1979 F-150
Agood way to estimate your gear ratio:
1.Jack up the rear of the truck and place on jack stands.
2.Place a chalk mark on the tire top center, and another on the driveshaft where you can see it.
3.Place truck in neutral
4.Rotate tire one revoloution, and count the number of driveshaft revoloutions.
Example: The driveshaft turns 3.5 times per tire rev.= 3.5*1, or 3.50 gears.
Old Oct 6, 2002 | 01:57 AM
whd507's Avatar
whd507
1979 F-150
