1978 - 1996 Big Bronco
stupid question
Old Aug 13, 2005 | 07:09 PM
bass4163's Avatar
bass4163
Question stupid question
hey guys...picked up a 94 bronco and for the life of me - or the dealers - cant figure out how to open the rear tailgate the handle on the inside feels as if its connected but pulling up nothing happens..the keyway on the outside of the tailgate brings the window up and down ok but does nothing for opening it up...is there a switch - button - something im missing or would it just be broken...thanks in advance
Old Aug 13, 2005 | 07:21 PM
BroncoRoadKill's Avatar
BroncoRoadKill
There should be a safety rod insaide the tailgate and the window pushes it when it goes all of the way down, the rod could of come loose or there could be something wrong with the latches. You can get a look at if you open the access panel on the inside of the tailgate.
Old Aug 13, 2005 | 08:34 PM
slickerthanyou's Avatar
slickerthanyou
Window must be all the way down then-When you remove the access panel there will be two rods connected to the handle mechanism pull the towards the center of tailgate and it will open. I do this on a daily basis as my hande was snapped off by my Hilift.-Bob
Old Aug 13, 2005 | 08:39 PM
MBBFord's Avatar
MBBFord
exactally what slickerthanyou said. The rods might of come off the inside of the latch some how. It should be easy to do once you get the panel off.
Old Aug 13, 2005 | 08:48 PM
bass4163's Avatar
bass4163
Talking
hey guys thanks for the replys that panel is coming off in the morning for a look see...i was starting to feel a little brain dead not being able to open a tailgate lol
Old Aug 17, 2005 | 08:30 PM
bass4163's Avatar
bass4163
hi...sorry for the delayed update..got that taligate opened turned out the window wasent seating all the way down...tryed some lube and it helped but still gets stuck a little going down...gonna have to try to get the window open when the tailgate is open must be a switch or something in there....
Old Aug 17, 2005 | 09:06 PM
Streetgang's Avatar
Streetgang
The switch is in the upper left hand side of the tail gate. You can just disconnect it and run a jumper over the two leads to make it think the tail gate is closed all the time.....I have done it before....you just HAVE to remember that you CAN NOT press the dash button with the TG down...and you CAN NOT close the TG with the glass in the up position.
