I just got a tilt column from a 78 F350 2x4.I want to put this in my 77 F100.The problem is I have a wire broken off and can't see where it is supposed to go.It looks to be red and gray and when I pull the signal cam wireing up i dont see any wire this colour.Does it go some where else in the column
does it look cut off? i have seen many of these like this matter a fact mine is like this. that wire is for the light in the gear selector if its not hooked up yours probably does not have the light. so ford just left the wire there.
Yes its red and grey it comes from the plug on the column.It does look just long enough to reach where the light should be for the gear indicater.But there is no light there
