Defueling the Engine
Old Aug 13, 2005 | 11:30 AM
laredo7mma's Avatar
laredo7mma
I know this may be an odd question since all of the modifications out there are to increase the engines power, but I have been wondering what would happen if you defueled the engine.
Would you get better longevity and fuel efficiency out of the 6.0 if you went to the power rating that the non-Ford International VT365 has?
Now don't get me wrong, I absolutely love my truck and it is basically stock except for the muffler delete pipe. It has had its "issues" but all of them have been taken care of by the fantastic service department I take it to (yes, I love my dealer!). I also love my current MPG (19.5 @ 70 unloaded), but being an Engineer, I am always thinking about different stuff and trying to figure them out.
My goal is to have my truck last for at least 10 years and 350,000 miles. My old 1992 F150 with the 302 went to 247,000 before I sold it. The engine was still strong and only using 1/2 quart of oil every 2500 miles.
So I will ask all you guys what you think would happen if I loaded in a defueled program for daily driving/commuting and then reverted back to stock when I need the extra power. Would it increase mpg and longevity or actually make the engine work harder at cruising speed because of the lowered torque/hp?
Old Aug 13, 2005 | 04:32 PM
toddyw's Avatar
toddyw
The best defueler should be your right foot. What it sounds like you are wanting to do is limit the total horsepower of your truck. Because a diesel engine injection system meters the fuel to regulate the power verses speed, this would end up being very flustrating to drive and you would end up with the throttle pedal on the floor most of the time, just trying to go up hills or even just taking off from a stop. IMO.
Old Aug 13, 2005 | 07:43 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Having a de-fueling program would do very little in my opinion.
You may be able to improve fuel economy by re optimising the injection timing, but a defueler is just effectively an egg under the accelerator pedal, if you drive sedately you it will be the same.
Same goes for lengevity. Drive it carefully, and be mechanically sympathetic to it and you should be fine.
Old Aug 13, 2005 | 07:54 PM
kw5413's Avatar
kw5413
Plus this engine wants and needs to be driven. Needs to growl and groan from time to time.
IMO...defueling a Ford 6.0 could actually be detrimental to it's life span. But, that's just me.
