Will this transfer case work with a c4?
Old Aug 13, 2005 | 09:54 AM
ClatonK's Avatar
ClatonK
I have a transfer case from a 83 full size Bronco that originally had a manual transmission and 302 in front of it. Will this transmission work with a C4 automatic?
Old Aug 14, 2005 | 09:07 AM
RTM's Avatar
RTM
You mean will the t-case work with a C4? The only C4 4x4 trans I know of was in the 66 to 77 broncos and they had D20 t-cases behind them. I don't think tis is a direct swap but it's been a while since I have followed the early broncos. Now if you ask will it bolt right up to a 2 wheel drive C4 trans then the answer is no it will not. Try advance Adapters and see if they have anything that will allow you to adapt the two together.
Old Aug 14, 2005 | 04:52 PM
Ponyracer's Avatar
Ponyracer
I would look for a 4X4 C-6 to install instead of the light duty C-4. The C-6 should be fairly easy to find as it would have been common in the broncos and F-series. Good Luck
whisler
Nov 17, 2013 04:17 PM
kcode
Dec 30, 2011 08:19 PM
Katmandu
Nov 19, 2008 08:38 PM
steve664x4
Dec 22, 2005 03:20 PM
petem
May 10, 2001 12:40 PM
