Typical Ford Dealer
</O
Ok so here's the good part. When I took it in for service I only had 39 miles till the warranty ran out. I don't understand how a "Trained" Ford tech can be under it working no more then a foot from the noticeable leak. This all took place on Saturday, and apparently it is impossible to get a tech to look at a leak. So I left a nasty message on my service advisors voicemail. First thing Monday morning service calls me, by now I am over my miles they inform me that I am "very lucky”, since I have parts on order (seat covers) the work order is still open and that they will cover it under the factory warranty. <O
<O
So is it me or does anyone else think that they saw the leak and thought they would be "very lucky" if I didn't notice it for another 1,000 miles? I will let everyone know.
He He He.... .. . I have convinced my local dealer that I am crazy. It is to bad that it has to come to this.
On the flip side the other dealer in my area that is about 30 minutes further away has been great. They have lent me specialized tools from there shop and gone the extra mile to help me with various Ford related projects. It really comes down to weather they care about me. I know where I will be getting my next truck. My wife wants a 05/06 GT Mustang. This means two new vehicles in the next 18 months. Guess where I will be going first.
Respectfully
Dean
), and due to 100 years of people yelling, "If I wanted it fixed i'da asked you to fix it!" Your situation is not really anyone's fault and just consider yourself lucky to have an accesible lift, as you caught it in time.
Now it's in for the second time for the rear diff. howl and broken lumbar seat adjustment.... also told them about something protruding out the back of the drivers seat trying to poke through the material. First time I asked about it, they didn't know and I had them highlight the problem on the work order with a highlighter. Next time I asked them about it, they still didn't know about it. I said I had told them twice about it and it was even highlighted..... he said they will see it on the work order. Now they called and said they ordered parts for the rear diff. ......... still didnt' know about the thing sticking out the back of the seat !!!
Took three trips there for the trans. clunk and they never did admit that my particular truck had a problem, but they did fix it !!??
So far two trips to get them to hear the rear end howl and I had to yell in the service department after they told me there was a sound, not bad enough to fix and that I should just let it "wear in" longer !! After that, they called me two days later and said that they heard the noise and are ordering parts. So truck has been in the shop 6 times for 4 problems and only one problem has been fixed so far. The truck has less then 9,000 miles on it. Of cours when I bought the vehicle they said that the service dept. will take really good care of me and I will get a loaner car anytime I have to leave it. So far only got a loaner twice out of the 6 times. From now on when they ask me when I can drop off the vehicle, I say....... whenever you have a loaner for me !! Of course, threatening to call the owner of the dealership didn't heart either!
There goes my blood pressure again.
Any warranty work done to a vehicle that wasn't a direct customer complaint gets red flagged and Ford may not pay for that job... basically if YOU don't notice it, the dealer isn't supposed to fix it, therefore the technicians are supposed to turn a "blind eye" to problems they find while doing maintenance to a vehicle.
I personally do not believe in this theory.. and I note all problems I find.. and I let the advisor decide what to fix - I did my job. I don't want the accountability if something were to turn sour right after I worked on it, even if not related to what I did.
On a good note, I'm quite impressed with the quality... I don't see a whole lot of problems like this.
You mentioned transmission controller? Are you referring to the solenoid? (takes several seconds to engage Reverse and then slams into gear?)
Make sure they use MERCON V fluid and the ford additive (ford had a recall for that additive on 2003-2004's), if your explorer is 2002 or newer. Seen a lot of solenoids go bad right after a quick lube did a transmission flush - a brass washer inside the solenoid expands due to a chemical reaction to the fluid and makes it stick. The fluid additive is supposed to prevent this from happening. Could be what burned up the first one.
Good luck
