iPod installation?
Old Aug 12, 2005 | 01:36 PM
hoytsauce's Avatar
hoytsauce
iPod installation?
Hey Y'all,
Anyone wire an iPod into their Expedition? Will Ford do it?
Charley
'05 Silver Expedition XLT, 2x4
Old Aug 12, 2005 | 05:11 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 14, 2005 | 07:53 PM
Onespeed24's Avatar
Onespeed24
Originally Posted by hoytsauce
Hey Y'all,
Charley
Well, that all depends on what head-unit you have. If it's the stock single CD player with a port for a CD Changer then all you will need is an adapter (I will look around later for exactly what you need. If it's a 6-disc changer, you will need a new HU. If you plan to go aftermarket, Kenwood and Pioneer make an adapter that is pretty easy to install and also charges your Ipod while in use. Alpine has a direct plug and play setup, but it is kinda expensive. I did a lot of research and finally ended up using the Kenwood HU that I took out of my old car, and a Kenwood adapter, it works great and sounds awesome. Let me know what HU you have and I can guide you in the right direction.
Old Aug 14, 2005 | 10:52 PM
Russell B's Avatar
Russell B
Visit Crutchfield.com & check out the interfaces for Fords. Supposed to work with stock head unit.
Old Aug 15, 2005 | 04:00 PM
npearman's Avatar
npearman
I used this
http://www.carplayer.com/
I had the 6 disc changer, which I took out after I installed the Ipod. It works pretty good. You get a much better connection (sound) than with a FM modulator. It's a little on the pricey side, but you can uninstall it and use it in another vehicle if you sell your expedition. You would just need to buy a compatable wiring harness for the new vehicle ($10). I also highly recoomend this
http://www.proclipusa.com/?sectionpa...tegoryid=13759
It too is a little pricey, but is the best mount by far. Mounts at the perfect height, is very stable and swivels.
Nathan
