Aerostar Ford Aerostar
Poor results
Old Aug 12, 2005 | 12:51 PM
VanGo's Avatar
VanGo
Poor results
I used a can of Seafoam in my '92 4.0 like the instructions say. Actually, I added more like a pint to the brake booster vacumn line and then put the rest in the tank. I was hoping the de-carbonizing would let me get back to using regular gas.
I get pinging now using plus-grade gas with the A/C on when I didn't used to before the treatment. Will this go away? The 89 octane used to prevent the pinging in the summer.
Old Aug 12, 2005 | 01:05 PM
copper_90680's Avatar
copper_90680
Check your transmission modulator. It may have a broken diaphgram. That would allow tranny fluid to go to the intake, causing lots of pinging under heavy load.
Old Aug 13, 2005 | 11:42 PM
Bear River's Avatar
Bear River
Former ******
Also, check your ignition timing, it may be overly advanced.
Old Aug 14, 2005 | 12:07 AM
96_4wdr's Avatar
96_4wdr
has all the Seafoam in the gas passed thru, usually takes 2-3 tanks to clear all out? Seafoam in fuel can cause pre ignition.
pull codes on ECU, may have bad injector or other problem that will put out a code.
don't think any of the Aero 4L ever were designed with a mechanical distributor but timing could be off in ECU programming. Ford played around with the ECU/PCM programming for several years on the 4L trying to get it right. Believe the 4L ECU/PCM electronic distributor sets idle timing at 10d BTDC with operating temp engine.
disconnect negative battery lead for 10 minutes so that ECU/PCM clears NOVRAM and defaults back to default factory programming and relearns parameters for your engine specifics.
pinging can also be caused by too hot a heat range of spark plug. pull plugs and check lt. tan or gray is good, all look the same, no blisters or large deposits? sometimes deposits can become lodged under the ground lug of plug that will not come out with Seafoam decarbonizing that will heat up and cause pre ignition.
Use only Autolite part # APP765 or Motorcraft Double Plats in the 4L, pre gapped to 0.054" but double check, someone is always opening boxes in store and dropping plugs.
try a pint of water down the brake booster tube, slow pour at 2 to 3,000 rpm.
Old Aug 14, 2005 | 08:29 AM
B-Aerostar's Avatar
B-Aerostar
Unhappy
I just started using 93 octane gas in my 95 AWD and the pinging stopped, also runs smoother. Still low gas mileage of 13 mpg.
