Sponsored by: Kumho
Sway bar help
Old Aug 11, 2005 | 06:05 AM
zzcharger's Avatar
zzcharger
Sway bar help
Hey guys and gals. I am Looking to try a sway bar on mu truck (91 f150 2wd) and am trying to find a factory sway bar to fit. I am looking for suggestions. If it helps I may get a bigger Addco unit. Here is what I am thinking. First off the local bone yard has a couple of mid 80s broncos that have them. I was thinking about getting one and seeing if it will bolt up since they should essentilly have the same ttb suspension with a few differences. I assume the mounting points will be the same but if course my 2 wheeler doesnt have the mounts at the wheel end, they look like they go under the spring and on top of the beam. Anyone know if this part is removable or swapable? Since the yard only wants 35 for it I may try it anyway. I am figuring the same for the rear. Any help or suggestions would be great! Thanks Jack
