Sponsored by: Real Truck
Newbie with remote entry problems
Old Aug 11, 2005 | 01:22 AM
onlyinaford's Avatar
onlyinaford
Thumbs up Newbie with remote entry problems
Hello all! I am new to this site so I hope I am posting in the right place. I purchased a 2003 F-250 3 days ago. The truck came with one factory entry remote that unfortunatly did not work. First thought was the battery. Change it and still did not work. Reprogram attempt and still nothing. Disconnected negative battery cable, reconnected and tried again; nothing???? Programed remote for wifes expedition and our explorer with no problems, but this one has me confused. When I try to reprogram the remote the locks do not lock and unlock to confirm reprogram mode? This one really has me stumped! Anyone have this problem or have any suggestions on what to do next? Thanks
Old Aug 12, 2005 | 05:57 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 12, 2005 | 06:55 AM
mstrfxit12's Avatar
mstrfxit12
Does it by chance have remote start? If it does, the key on key off method is not the way into progamming mode.
Old Aug 12, 2005 | 02:18 PM
Wrenchtraveller's Avatar
Wrenchtraveller
Sometimes the electrical actuators in the door go haywire. If the locks work with with the door buttons that is probably not the problem. Good luck .
Old Aug 12, 2005 | 03:02 PM
onlyinaford
No remote start? I took the truck to the dealer and was told that because the truck was purchased in Texas the southwest region uses different keyless entry types than central region! How rediculous is that!!! No help from the dealer. I have no idea what to do next???? Thanks for your input mstrfxit12!
Old Aug 12, 2005 | 03:10 PM
onlyinaford
Auctuators work fine so I know that is not it. I appreciate the reply wrenchtraveller! I am extemely confused, but determined to get this thing figured out! Thanks for the help!
Old Aug 12, 2005 | 05:32 PM
Jokenring's Avatar
Jokenring
Try pulling the remote apart and cleaning the battery contacts. Mine quit working and after cleaning the contacts worked just fine. Q-tip and some rubbing alcohol work good. Also look at the contacts on the chip under the button, if they are dirty, a quick clean will help.
Old Aug 12, 2005 | 06:15 PM
Rongold's Avatar
Rongold
Keyless Entry
Are you sure that the truck is equipped with keyless entry ??? My 2003 F-250 XLT is not. If you cycle the ignition on & off 8 times, do the lock actuators cycle down & up ??? If they don't, like mine, then the truck is probably not equipped with that option.
RON
Old Aug 12, 2005 | 07:38 PM
onlyinaford
Thanks for the advice fellas. I will give it a good cleaning to see if there is any difference. I am almost certain that it has the keyless entry option because it came with the remote and has what I believe to be the keyless entry module under the dash to the left of the steering column. Do you guys think that it could possibly be a faulty module? I am thinking that might be the problem and not the remote. If it will not confirm program mode after on/off program cycle. What do you think???
