1991 brake problems
Old Aug 10, 2005 | 11:37 PM
effie61's Avatar
effie61
1991 brake problems
i have a 1991 f250 4x4 diesel maybe some one out there has answer to my ? ,i have a soft brake pedal and it it also slowly fades to the floor , i have had the master cly , front rotors and brake pads and shoes replaced and the system blead , if any one can help ,
Old Aug 11, 2005 | 01:10 AM
butch a 250 d's Avatar
butch a 250 d
was the master cyl a new or rebuilt one if you are not losing brake fluid it just might be a faulty master cyl it has hapened before
good luck
Old Aug 11, 2005 | 07:20 AM
PLC7.3's Avatar
PLC7.3
Check out this info.... http://www.asashop.org/autoinc/dec99/techtips.htm
Old Aug 11, 2005 | 10:42 AM
butch a 250 d
thats a great piece of info iwas not thinking of abs brakes
Old Aug 11, 2005 | 09:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Rebuilt master cylinders are not what they used to be.
I had one on my truck starting to fail, so I got a rebuilt master cylinder and all was well.
Started up the road with a couple tons of iron water pipe on the truck and within 30 miles the brakes were worse than the old master cylinder was.
Made it back to town and changed the master cylinder again. This one has been working for 6 months so far.
Slowly fading to the floor when you are not losing fluid is often a bad master cylinder.
