General Automotive Discussion
1995 grand cherokee
Old Aug 10, 2005 | 06:47 PM
Hyperactive460's Avatar
Hyperactive460
1995 grand cherokee
my cherokee is doing something funny, as i'm driving down the highway it acts as if it's running out of gas or misfirering. when i shut it off at home and trieds to restart it 10 minutes later it wouldn't stay running , acted like it was loaded up. i just put in new plugs ,wires, cap and rotor last week. i ran the codes by turning the key on and off but have noway of knowing what they mean.......1st code = 12, 2nd code = 44 and 3rd code = 55. any help is gratefully appreciated..
andy
Old Aug 11, 2005 | 05:34 AM
rebocardo's Avatar
rebocardo
Try changing the fuel filter, I have fixed a bunch of Cherokees doing just that. It should be located on the driver's side, near the gas tank. Wear a splash shield or eye protection when changing the filer, remove the gas cap. You should have a valve under the hood to relieve pressure, but, I have never needed it on a vehicle that has sat for ten minutes. The Cherokee should use (at least the ones I did) a filter like the Fords with the plastic clips so no special tools are needed.
Old Aug 16, 2005 | 11:29 PM
Hyperactive460
thanks for replying, the fuel filter is new as is the fuel pump. i changed the pick up coil and it seemed to help it from cutting out while driving , but now it's stalling when ever i hit the brakes or turn a corner.......
Old Aug 17, 2005 | 01:18 AM
go_racing84's Avatar
go_racing84
http://www.jedi.com/obiwan/jeep/dtc.html
There's the trouble code list I've used in the past (not my page, however). Looks like you've got Coolant temp sensor problem.
Old Aug 17, 2005 | 08:12 AM
Hyperactive460
thanks go_racing 84. i just ran the codes this morning. one code appeared ( 54 ),according to your chart it's a "no fuel sync( camshaft signal ) detected during engine cranking". if i have time i'll try to stop by a garage and talk to them about it. thanks for the reply......
andy
