Removable Doors
Old Aug 10, 2005 | 12:23 AM
HATCHETT's Avatar
HATCHETT
Removable Doors
Does anybody know where you can order removable doors for a 78 F250? Or any of you fabricaters out there want to make some cash?
Old Aug 10, 2005 | 11:12 AM
thesprocket26's Avatar
thesprocket26
There should be like 4 bolts to remove your doors.
Old Aug 10, 2005 | 09:04 PM
HATCHETT's Avatar
HATCHETT
i know. i want some doors like for jeeps, that you can take off and put back on in less than 10 mins. i didnt know if they made them for ford trucks.
Old Aug 10, 2005 | 09:41 PM
theonlybull's Avatar
theonlybull
sure, just make some longer pins, with a cotter pin in the bottom
Old Aug 10, 2005 | 10:28 PM
dynamic's Avatar
dynamic
Just remember.... The fuzzz...
I had a buddie that made some "Jeep Style" doors for his cheeroke, The problem was that the doors didnt fill the hole and match up like a factory set. They sat inward and left a gaping hole where the fender and the door were susposed to meet up.
My advise would be to take a pair of doors, take all the glass out, and the window hardware, then cut out the extra metal and make the doors extra light...
Then cut out the center pins and put in some handle style pins with clips to hold them in.
Depending on your local Fuzz... you might have to leave the "doors" on when on the highways, and remove them for wheeling....
Old Aug 10, 2005 | 11:51 PM
HATCHETT's Avatar
HATCHETT
alright that sounds like a plan. thanks for the input
Old Aug 11, 2005 | 01:29 AM
ivanribic's Avatar
ivanribic
Most states won't allow it but what I'd like to do is get 2 spare doors and cut them across the middle (from left to right) taking the window frame off and then notch the center low but leave the sides so you still have hinges and a latch. It would make a nice low half door that you could see out of easily.
