Wandering Gauges
Old Oct 15, 2002 | 12:49 PM
stump's Avatar
stump
Wandering Gauges
1974 F100, 360, c6. My gas, temp, & oil pressure gauges all wander at the same time in the same direction. They'll move slightly to the right and then back with no rhyme nor reason. Obviously, this makes their accuracy in question. Do all gauages share a common wire that might be shorting out some how? Any advise to point me in the correct direction would be greatly appreciated.
Old Oct 15, 2002 | 01:36 PM
TheWiz427's Avatar
TheWiz427
Wandering Gauges
Old Oct 15, 2002 | 01:47 PM
Franklin2's Avatar
Franklin2
Wandering Gauges
Ford uses a regulator for the voltage supply to the guages. It usually is mounted to the circuit board on back of the instrument cluster. Take the cluster out, and it should be a little metal box with two electrical connections coming out of it.
Old Oct 15, 2002 | 02:54 PM
FlintK's Avatar
FlintK
Wandering Gauges
Check and make sure that the ground strap is hooked up from the engine block to the body of the truck. An improper/non-existent ground can cause wondering gauges.
Old Oct 15, 2002 | 03:05 PM
stump's Avatar
stump
Wandering Gauges
is this something I can buy new at an auto parts store?
Old Oct 15, 2002 | 03:48 PM
76supercab's Avatar
76supercab
Wandering Gauges
Yes. It's called the instrument voltage regulator. I got one at a chain auto parts store but they had to order it in. You might have to force the person behind the counter to LOOK IN A BOOK but they are available. Should be less than $20
