few 87 questions:
Old Aug 9, 2005 | 11:16 PM
Psycho Jimmy's Avatar
Psycho Jimmy
few 87 questions:
i tried a search of each but answers danced around it or wasn't for my model year specifically....
tach wiring for this truck i know early/mid 90's had the tach signal already installed but my 87? if not there are like 8 wires coming out of my distributor which is my signal wire???
i'm putting a C6 in it with a 1800 stall B/M t/c and replacing the 3rd AOD, i have a 9 inch freshened and set up w/ a 4:11, this truck is my weekend cruiser but am i going to be wound out at like 50 mph if i use them both or what???
any good rear disc brake conversions out there other than the crap on ebay??
thanks for the help....i'm new
Old Aug 10, 2005 | 04:47 PM
EPNCSU2006's Avatar
EPNCSU2006
Tach signal should be coming from the negative side of the ignition coil. My '87 has a tach from the factory, so I'm guessing it is probably wired for one already.
Old Aug 10, 2005 | 11:28 PM
Psycho Jimmy
i got the tach figured out tonight after some plugging with my DVOM i found i didn't have the harness for a tach, the dead plug was connected to some cruise control crap it looked like...
any help on my other 2 questions?
Old Aug 12, 2005 | 05:56 AM
EPNCSU2006's Avatar
EPNCSU2006
I don't know much about the auto's, but I would guess that highway speed cruising with the C6 and 4.11 gears will be mighty high rpms. There are several rear disc swaps, here's one I've found: http://www.tsmmfg.com/Ford_truck_rear_axles.htm
Old Aug 12, 2005 | 07:40 AM
18fan's Avatar
18fan
I dont remember which wires I moved, but I installed a cluster with the tach in the 87 I used to have. I believe the wire from the coil you need to tie into is green. Also a couple of the wires in in the connectors that plug into the back of the cluster will need to be moved to a different spot in the harness. It was several years ago when I did this but after I figured out which wires needed to be moved it was very easy. I used a haynes manual and just compared the new guage cluster to the old 1 to see where the different connections went. My 87 had 410 gears with the AOD trans. But it also had 16" tires. I found a new set at a tire shop someone had special ordered and never picked up. Got them for less than half what they cost. Made my 87 look good. Sorry I could not be more help.
