Will it fit...
Old Aug 9, 2005 | 11:11 PM
Jason8705's Avatar
Jason8705
Will it fit...
Will aftermarket parts for a 5.0 EFI from a Mustang fit my 5.0 EFI in my F150???
Old Aug 10, 2005 | 08:00 AM
TigerDan's Avatar
TigerDan
Yes, for the most part, a 5.0 is a 5.0. Will they work on your truck? That's a different matter altogether. Here's another thread on the subject:
https://www.ford-trucks.com/forums/s...d.php?t=394023
As is pointed out in the thread, a truck is heavier than a Mustang and is designed to use its power in a lower RPM range than the 'Stang. It has a different design intake that helps produce more low RPM torque, and a different cam. You have to be very careful in selecting what parts to use or you could screw up the driveabilty.
Old Aug 10, 2005 | 11:31 PM
Icicle's Avatar
Icicle
Or have drivability and no performance......
It would suck to spend all that money and not get anything out of it, other than less power.
What Mustang Mod part are you looking into using on your truck motor?
Old Aug 11, 2005 | 01:36 AM
cjjeeper85's Avatar
cjjeeper85
This would have been eaiser if you asked what won't fit. LOL
As tigerdan said a 5.0 is 5.0 so you don't have to worry to much about the parts fitting the motor, instead you have to worry about the parts fitting in the truck.
