Sponsored by: Real Truck
Backup sensor sys. not working
Old Aug 9, 2005 | 10:08 PM
sneak's Avatar
sneak
Thumbs down Backup sensor sys. not working
I have an 02 350 7.3 crew short, with 120 k miles, and the back up sensors stopped working on me, it just turns itself off automaticaly. Has any one had this happen to them?
Old Aug 10, 2005 | 04:07 AM
slc10844's Avatar
slc10844
Had the same problem and took it back to the dealer for warranty repair. They found one bad sensor in the bumper. According to the manual, it takes special equipment to diagnose the system. I don't know if testing the sensors with an ohm meter will tell which one is bad. I guess you could buy one sensor and rotate it through until it starts working again. If two are bad, it may be a problem.
Old Aug 24, 2005 | 12:48 PM
sneak's Avatar
sneak
Ok, thanks very much, I will try that.
Old Aug 24, 2005 | 02:34 PM
wiingnut's Avatar
wiingnut
That happened to my wife's explorer but I couldn't tell you the solution. It didn't get fixed till I traded it in
