Steering columns
Old Oct 15, 2002 | 02:12 PM
Djoffroad's Avatar
Djoffroad
Steering columns
After an eventfull weekend rolling my truck, I now need a new steerng column. Is there a tilt setup that will adapt easily into my 76 F100?
Silly rabbit. Jeeps are for chicks!!
"If you're not getting stuck, you're not trying"
76 F100
Old Oct 15, 2002 | 11:21 PM
Quadiquizm's Avatar
Quadiquizm
Steering columns
YUP - as far as I know 73-79's are all the same - but I think 2WD to 4WD have to be modified. Right Guys?
Keep it Rubber Side Down!
Old Oct 15, 2002 | 11:27 PM
heathdaily's Avatar
heathdaily
Steering columns
I replaced my tilt column in my 79 F-250 2wd. The old tilt didn't have cruise. The new one did. After that, the horn button would short out the headlights. Fun, huh? You could probably re-arrange the wiring to avoid this but I thought you'd want to know about it.
Old Oct 16, 2002 | 12:05 AM
TKONO's Avatar
TKONO
Steering columns
a 2wd tilt column will bolt right into a 4wd. And any 2wd straight column will work in a 4wd if you change the center shaft. good luck
Old Oct 16, 2002 | 05:21 AM
theonlybull's Avatar
theonlybull
Steering columns
i belive the tilt was only in the 78/79 trucks.... my 79 has it, my 78 doesn't... thank god... personally i hate the tilt column.
Old Oct 16, 2002 | 04:25 PM
gustafson's Avatar
gustafson
Steering columns
I believe the neutral safty switch is in the column 73-76 and in the tranny from 77-79? not positive but was told that from ford guy when I found a tilt cruise unit for mine out of a 79 bronco.
Old Oct 16, 2002 | 05:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
Steering columns
