Clutch/Flywheel Problem
Old Aug 9, 2005 | 01:54 PM
libsys's Avatar
libsys
Question Clutch/Flywheel Problem
Hi all... new to the forum. I'm starting to get some chatter when starting up from a stop (some in 1st gear, mostly in 2nd). I only notice it when the truck has been run long and hard, when everything is good and hot. Based on what I have read, it appears that it could be caused by either the clutch or slippage in the dual mass flywheel. Any thoughts on how to further diagnose and isolate the problem. Since heat seems to be the determining factor, does that help pinpoint what's causing it? Thanks!
Old Aug 9, 2005 | 05:02 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
