Blue/White Smoke??
Old Aug 8, 2005 | 11:33 PM
dieselpuller's Avatar
dieselpuller
Cool Blue/White Smoke??
When i floor it in (N) about 2000rpm the engine cuts out and blue/white smoke comes from the exhaust, then clears out at about 2500rpm. Also driving down the road, it does the same thing at about 2000rpm and has some lag until the turbo spools up at 2500rpm the runs great?? It is a 99 powerstroke. It has had a headgasket replaced, push rod that was bent replaces, valve cover gaskets replaced, and two wiring harnesses. Runs better now but this blue/white smoke problem?? Help!
